unlocked cores, overclocked just built have a question..
Status
Not open for further replies.
dajohnso
25
me and a buddy just put together a new computer using a amd phenom II x2 555BE, we unlocked the cores and put it under load for an hour everything was fine, then overclocked it and ended up at 3.8 everything is running fine.
the problem im having may have nothing to do with my cpu but when i was playing mw2 just now for the first time on this machine the game would freeze at times and then i would get D/C from the server, this happened several times till i stoped and a similar thing happened in wow also but it only happened once and it didnt D/C me because it takes alot longer for the game to kick you in that game.
i am running directx11 and the newest ati drivers my card didnt have any problems in my other PC but i was running dx9
heres the systems spec if anyone has any ideas that would be nice, also first time posting so hi =P
Field Value
Computer
Computer Name STEAKBAJA-PC
Computer Type ACPI x64-based PC
Date / Time 2010-09-30 / 21:25
DirectX DirectX 11.0
Internet Explorer 8.0.7600.16385
Logon Domain steakbaja-PC
Operating System Microsoft Windows 7 Ultimate
OS Service Pack -
User Name steakbaja
Motherboard
BIOS Type AMI (04/23/10)
Communication Port Communications Port (COM1)
Communication Port Printer Port (LPT1)
CPU Type QuadCore AMD Phenom II X4 Black Edition B55, 3800 MHz (19 x 200)
DIMM1: Corsair XMS3 CM3X2G1333C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM2: Corsair XMS3 CM3X2G1333C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
Motherboard Chipset AMD 785G, AMD K10
Motherboard Name MSI 785GM-E65 (MS-7596) (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR3 DIMM, Audio, Video, Gigabit LAN, IEEE-1394)
System Memory 4096 MB (DDR3-1333 DDR3 SDRAM)
Display
3D Accelerator ATI EG Redwood XT
Monitor Mitsubishi DiamondPoint SB70 [17" CRT] (3570005YA)
Video Adapter ATI Radeon HD 5600 Series (1024 MB)
Multimedia
Audio Adapter High Definition Audio Controller [1002-AA60] [NoDB]
Audio Adapter Realtek ALC889 @ ATI SB750 - High Definition Audio Controller
Storage
Disk Drive ST3500418AS ATA Device (500 GB, 7200 RPM, SATA-II)
IDE Controller Standard Dual Channel PCI IDE Controller
Optical Drive TSSTcorp CD/DVDW TS-H653L ATA Device (DVD+R9:8x, DVD-R9:8x, DVD+RW:18x/8x, DVD-RW:18x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Partitions
C: (NTFS) 455.9 GB (410.1 GB free)
F: (FAT32) 9986 MB (5893 MB free)
Total Size 465.6 GB (415.8 GB free)
Input
Keyboard Standard PS/2 Keyboard
Mouse HID-compliant mouse
Network
Network Adapter Linksys AE1000 (192.168.1.101)
Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Primary IP Address 192.168.1.101
Primary MAC Address 00-25-9C-F8-FF-98
Peripherals
Printer Fax
Printer Microsoft XPS Document Writer
USB Device Linksys AE1000
USB Device USB Input Device
USB1 Controller ATI SB750 - OHCI USB Controller
USB2 Controller ATI SB750 - EHCI USB 2.0 Controller
DMI
DMI BIOS Vendor American Megatrends Inc.
DMI BIOS Version V2.6
DMI Chassis Asset Tag To Be Filled By O.E.M.
DMI Chassis Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
DMI Chassis Serial Number To Be Filled By O.E.M.
DMI Chassis Type Desktop Case
DMI Chassis Version 1.0
DMI Motherboard Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
DMI Motherboard Product 785GM-E51 (MS-7596)
DMI Motherboard Serial Number To be filled by O.E.M.
DMI Motherboard Version 1.0
DMI System Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
DMI System Product MS-7596
DMI System Serial Number To Be Filled By O.E.M.
DMI System UUID 00000000-00000000-00006C62-6D0735B1
DMI System Version 1.0
Status
