Originally posted by: Lonyo
SuperPi is a quick and easy test of CPU.
If you can't get to 2M (and get a SQR RT error) then your CPU needs more juice (up the voltage).
If you get a not exact in round error, then your RAM is messed up.
I have my CPU oc'd to 2300, and my RAM (Kingston) at stock, yet the blend torture test will usually kick out a rounding error after 3-4 hours. Should I RMA my ram? I shouldn't have to bump the voltage if it's at stock.
Originally posted by: Jeff7181
It should have zero problem running 2.2 GHz on 1.65 volts since that's what a normal XP3200 runs at and it uses the same heatsink as an XP2500.
but the reason it's sold as XP 2500+ is because they test it and see if it can operate 2.2GHz with the stock voltage, and only then they will mark it as 3200+. but many 2500+ are capable of 3200+ performance, just the odds are they may need a little more juice.
or to put it another way: a cpu sold as 3200+ is tested and verified to be able to run at 2.2GHz with stock voltage, while a 2500+ can probably get to 2.2GHz but is not guaranteed to do so (it may also need higher voltage). From this you can deduce that a 3200+ has a better chance of achieving higher clock speeds that a 2500+, but that's not always the case since neither was tested at higher speeds.
