unlock your car using a tennis ball
hjo3
7,354
4
You can do it with a plunger too. But it only works on cars with vacuum locks.
Midlander
2,456
It's easier with a garden hose. You just turn it on full blast.
Don't do it in the winter, though, because your locks will freeze.
eelw
10,228
5,343
Sure why not. We always carry around a garden hose and a water source.
AaronB
1,214
It's bs.
Volume of the door is too great for the air displaced by squeezing the ball to increase pressure to the point where the lock is popped up. Add in the fact the door isn't even air tight and I doubt that you will even create a measureable pressure spike.
Mrvile
14,066
Originally posted by: AaronB
It's bs.
What about using a plunger?
AaronB
1,214
It's bs.
I won't say that is impossible but you couldn't do it just by plunging the key hole. That hole is too small for air to pass through quickly enough. (remember the door isn't air tight)
I suppose it would be worth a try if you plunged the door handle since there are probably larger gaps there.
AStar617
4,983
Originally posted by: smopoim86
Is there really such thing as vacuum locks?
Absolutely. The 80s Mercedes-Benz S-Class is one model that comes to mind... unlike usual power door locks where all of them snap locked/unlocked in unison immediately, when you turn the key the locks take about two seconds to actuate, and each door lock's completion is usually slightly staggered from the rest... the low whine noise of the system is pretty unique too, sounds like a hydraulic foley effect for a cyborg movie. :)
hjo3
7,354
4
Yup. Read about it on Boing Boing.
EDIT: This story was covered by Boing Boing and Digg two weeks ago.
Midlander
2,456
It's bs.
Drilling a 1" diameter hole in the door should work if you find the other openings are too small.
