Hi guys,
I'm having a problem with unknown USB device that keeps showing up in my device manager. What's worst is that sometimes it pops in and out as if the device is being discovered, rendering my front panel USB ports unusable and sometimes my keyboard/mice (both are USB) I'm not sure if this is Windows XP related or hardware related. The last thing I did was install Creative Audiogy ZS but have since removed it and its associated drivers.
This is my setup:
WinXP sp2 (with latest update) on AB9 QuadGT, its P965 chipset. There is no additional PCI cards except for Video.
Here is what I did thus far (without success)
1.
* Detach all usb devices, including front panel usb
* Reboot to Safe move, remove all USB entries under device manager
* Shutdown, unplugged for few hours
* Reboot
* Without attaching ANY usb device, check device manger: Unknown usb device still shows up, problem still exists.
2.
* Reboot, enter bios, disable USB controller
* Boot up Windows, check device manager, shows no usb entries.
* Restart, enter bios, enable USB controller
* Boot up Windows, allowing Windows to recognize USB, check device manager, still unknown usb device.
3.
* RegEdit and remove all entries that I can find with VID000.
reboot
Because of this issue, I have updated BIOS to 1.6 and Intel Chipset driver (latest) from Intel website. The above were all done with the updates.
I'm starting to wonder if the USB ports on my QuadGT is shot.
Anything else I can try?
Help is greatly appreciated!
This is my setup:
1.
* Reboot
2.
3.
reboot
