- Nov 9, 2004
- 3
- 0
- 0
Hi
I?ve recently come home to find out that my cousin has switched off my pc at the wall plug(might have done it quite a few times - he's 1 year old).
Yes, this as you can imagine, is what started my problems. I then switched my pc back on and my screen and fans started up fine(they had power) and my keyboard's lights started flashing, but nothing appeared on the screen and not my hd or stiffy drive made any sounds. No beeps, no sound, nothing came from the pc.
This is what I checked:
- the cabling.
- used another screen in case my screen had blown.
- put in another screencard in case that had blown.
- took out hd in case that was the problem.
- took out all my RAM.
Still, nothing appeared on the screen when I switch on my pc and still no sounds either, except for the fans. Since the fans started up, I ruled out my psu. Only thing to my knowledge that was left, was my cpu or mobo. So, I went out and bought a new mobo and cpu(needed an upgrade anyway). But, to my surprise, when I put them in, the problem was still there. NOOOO.
Anyone have any idea what the problem might be? Pls help.
Thx
- the cabling.
Thx
