tweeve2002
I know this has to be hardware. but the system is running just about perfect. besides having almost no hard drive space. All I know is when EVEREST Home Edition runs the hardware scan the system bluescreens. Unfortunily it dose not tell me what hardware crashed so I cant fix it, and whe I do get back into windows, It dosnt do the crash report so I cant check that way either. It is draving me nuts. I want run some hardware monitoring software but most of them crash the computer.
Any help they to find out what is crashing it would be great.
System specs:
CPU: P4C 3.0Ghz
RAM: 1GB Musken PC4000
PSU: PC Power and Cooling 850W
Video: XFX 128MB 6600GT
Sound: Audigy 2
RAID 1: 2x WD 120GB, RAID 0 config, on the build in VIA RAID
RAID 2: 2x WD 80GB, RAID 0 config, on addin Highpoint RAID card
RAID 3: 2x Seagate 300GB, RAID 0, on the build in INTEL RAID
RAID 4: 2x Seagate 500GB drives, each set as a RAID 0, so it shows up as 2 drives NOT 1
System heat monitor by MBM5 - CPU 30C, CASE 32C
MBM5 is the only monitoring software that works without crashing.
Voltages: All voltages are monitored though MBM - System has been running sence sunday.
3.3 Volt - Current 2.94, High 3.14, Low 2.78, Average 3.1
5 Volt - Cuttent 5.00, High 5.05, Low 4.92, Average 4.99
12 Volt - Current 11.98, High 12.16, Low 11.80, average 11.96
Note: one of the 300GB Seagates is acting up. It has a hard time starting and makes a clicking noise when starting but once it started runs fine. I am in the process of burning all the data off the 600GB RAID on to DVD so I can split the RAID into 2 drives so when one drive dies I dont lose a ton of ingo.
System specs:
CPU: P4C 3.0Ghz
Sound: Audigy 2
