If you had the roku box it would be easier/cheaper because it accepts IR signals as well as the wifi direct connection it's own remote uses. Since you have the stick I think you'd have to use something like the Logitech harmony hub, which is the only thing I know that claims to be able to control the roku stick in addition to other IR devices.
