Universal Card Reader (Disk is write-protected)
MASTERT
129
I'm using Radio Shack's 10-in-1 Card Reader
when i am done transfering the images to my hard drive i want to delete them.
when i try to delete them it says
"Cannot delete filename: The disk is Write-Protected.
Remove the write-protection or use another disk"
the only way i know of removing the write protection is with the switch on the chip... but the switch doesn't help at all.
PLEASE HELP! this is for the company i work for and we are all stumped.
corkyg
Elite Member | Peripherals
27,370
239
It would seem to me that the problem is with the media - I suspect somehow it has become write protected and the switch doesn't work.
Have your tried contacting the maker of the SD chip? Have you tried it in a different reader?
pikachu656
200
Reboot and see if you can delete it afterwards. Sometimes I have files that I can't delete on my computer and it's tells me the same thing, after rebooting the machine I can delete them.
corkyg
27,370
239
Really think you should try it on a another reader - preferably not a multi-format reader.
MASTERT
129
I have a eMachine at home with a universal reader in the case... I think i will try that tonight.
We've started buying kingston and corsairs hoping they won't have the same problem... i haven't recieved any of those chips yet so i'm not sure
What's weird is that one of the chips we tried worked. it was that same KODAK chip but it was purpleish color instead of black. we have like 7 of these damn KODAK SD 64mb chips.
MASTERT
129
ok i just got another purpleish one it's 32mb and it's write-protected :( so not all the purple guys are good
corkyg
27,370
239
The other thing you can do, since you have off loaded the images, etc. onto your hard drive, is to try and format the SD module in your camera.
That would be a good independent check to see if it is in fact the chip or a faulty 10-in-1 reader.
MASTERT
129
after that 32mb purple one i got a 64mb purple one (Kodak Ditigal Fim SD Flash Memory) and it worked! i don't get it
MASTERT
129
i tried formatting through windows explorer (right click on drive and goto format) and it says "The disk is write-protected"
corkyg
27,370
239
If it says that and the write protect switch is off, it apparently doesn't work. The SD module has gone South and needs to be replaced. Try the folks at Kodak for that option.
Kodak SD
Also - this looks like it's worth a shot:
Tape
MASTERT
129
I've emailed Lexar (i guess they handle tech support) no response yet
i saw taht suggestion before and tried it with no luck
i was thinking maybe there's a back door
because i'm guessing XP is the problem... if maybe i boot up with something else and do it that way
Steelerz37
693
sound slike the same problem I am having.. I bought my gf a sandisk 1gb SD media stick for her digital camera. It works just fine in the camera reads/writes. but I can not write back to the memory through windows, but the camera writes to the media just fine.
Mavrick007
3,198
It could be the reader. I have a card which I was able to view fine in the camera, but my reader wouldn't pick it up any more, it keeps saying that there's no card in the drive even though the light is on for the memory slot. I tried my friend's reader and it worked fine on my computer so I'm buying a new flash card reader.
Try deleting the pics from the camera itself. If that works, try using a different reader.
MASTERT
129
Deleteing from the camera works
I sent a request to purchasing for a new reader hopefully they get me a good one.
I'll let you guys know how it goes on mon. maybe
thx for the help
