Units of Torque
soydios
2,708
torque = (mass) x (acceleration) x (distance)
Newton-meter = Newton(kg x m/s2) x meters
ft-lbs = lbs(slugs x ft/s2) x feet
SI units FTW: Newton-meters
LordMorpheus
6,871
Joules is inaccurate - a torque is not an energy.
The equation Work = Force * Distance gives an energy when you have a force acting in line with the displacement. For a torque, the force is acting perpendicular to your distance.
Joules is wrong.
Colt45
19,720
for power, hp or kW make no difference to me, but for some reason I can never remember conversion between ftlbs and nm.
so foot pounds then
FleshLight
6,883
It depends on what system you're using.
T = r X F
r is in any measurement you want, ft., in., m, M, pm, etc
F is in Newtons.
Demon-Xanth
20,551
Joules is a measurement of energy. Nm is a measure of torque. They differ in the scope of thier measurement. A joule is the work done by exerting 1 newton over 1 meter. However, when you exert 1 newton of force on a 1m wrench and the bolt does not turn, you still have 1 Nm of torque, however you have done no work.
LS20
Banned
Jan 22, 2002
5,858
Originally posted by: 91TTZ
All the kiddies who want to act "euro" prefer N.m
All the real gearheads will prefer ft*lbs if they're from the US.
Just about all US documentation refers to torque in ft*lbs.
All scientists and engineers and otherwise educated people prefer N*m
All the real ignant rednecks prefer ft*lbs
(atleast they use Liter displacement... thats a start...)
skyking
22,362
5,322
Nicely put. I use ft/lb because all the old stuff I work on uses ft/lb in the manuals.
WhiteKnight
2,952
Joules is wrong.
I can't believe that it took so long for someone to point this out.
Paperdoc
2,340
291
Has to be Nm. Torque is the product of a force (acting tangentially arout a rotational point) times a distance from the centre to the point of application of the force. So units have to be (force) x (distance), like NM or ft-lb or in-lb.
Joules are a unit of energy - not force , not work. You cannot convert a specified quantity of energy into a force or a torque.
Vegitto
5,234
Originally posted by: Chaotic42
I like (N*m*s*gals)/(qt*min)
You like (Newtons*meters*angle*volume)/(quarts/minute)? :confused:
What will that give you? How fast something with x torque will fill a gallon from x meters under an angle of x degrees? :p
Raduque
13,140
138
I give you :thumbsdown:. Real men measure displacement in Cubic Inches, power in Horsepower and Torque in ft-lbs.
Howard
47,982
10
blah blah blah
Yes, sir!
Mo0o
24,227
I use N*m since they're SI units. I usually dont use Joules, which i reserve for energy
silverpig
27,703
11
It's not Joules because a torque is a vector quantity, which is a cross product of two vectors (radial distance and force). Energy (Joules) is a scalar quantity coming from a dot product.
pray4mojo
3,647
oh right and dont forget psi instead of bar.
