Fenixgoon
So I was swapping back to my summer tires the other day and I checked my brake pad thickness.
Rears have way more life than the front, no surprise there.
But on the front pads, the outside pad was thicker than the inside pad by about 1mm. The pads also had a gap at the top between the pad and the rotor, whereas the midsection of the pad sat perfectly flush with the rotor.
Is that a problem? Any idea what would cause that?
