- Oct 14, 2012
- 2,401
- 1
- 91
Underclock to get lowest power draw
Hi, I'm trying to underclock my PC for times that I need to leave it on but save on power bills.
I'm using an i5 750 and a MSI P55-GD65
1. So far I've dropped the core amounts from 4 to 2
2. Lowered the Memory to its lowest setting and voltage 754MHz (1.5v)
3. Reduced the BCLK to 125 (it doesn't cold boot from any lower)
4. Dropped the CPU multiplier to 10 so the CPU ranges from (1131-3016) MHz
5. Also dropped the QPI to 4000MHz
At these settings it is drawing 77W from the wall when idle
My Stock setting it draws between 80 and 84 from the wall when Idle
And at my overclocked 3800MHz it draws between 104-105 when Idle
Im thinking is there anything I can do voltage-wise to lower the idle wattage especially considering there are only 2 cores running. Anyone Tried this before?
