- Nov 27, 2001
- 1,072
- 11
- 81
I had another thread that was tied into this question, but at the time I thought it was another issue.  The drive was NTFS and I changed it back to FAT32.  Now I'm running into the same problem, but the drive was Fat32 already.
I have always used Fdisk to partition my hard drives. I deleted the partition, create a primary and a extended and format them within Windows setup. The drives were/are 20GB. I'm confortable with it and at this basic level it seems to work fine. I only create 2 partitions, nothing fancy. After doing so, I use a bootable CD with 2k and sp3 slipstreamed to install the O/S. I don't know if this is the reason or something else, but the last two times I did this, when I enter the Windows setup there is some unallocated space on the primary partition that Fdisk didn't show. This shows up in Partition Magic also along with the Windows setup. The first time it was 7.8 MB, not a big deal. The 2nd time it is 180 MB, a BIG deal!
Others mentioned that Windows needs space for the setup files (that get deleted after setup), but isn't that within the partition wher the O/S gets loaded? This unallocated space isn't formatted so it can't be used, right?
I don't know what I'm doing wrong unless it is some quirk with this bootable CD. BTW, I'm using FAT32
 Facebook
Facebook Twitter
Twitter
