hmmm, i should of gave more information. Its a dial up line, he just installed the dnet.exe file, we were on icq and he had no problems with his connection. I guess the question is whether or not the client fetched any blocks to start the job.
what happens quite often is that the client is unable to resolve the keyservers domain properly. Try to make him fetch/flush to an IP-address, that usually helps.
