I am trying to fine-tune my parents new Dimension E521 (NVidia 6150 LE integrated graphics).
The monitor is a 19-inch Dell 1907FP with a 1280x1024 native resolution. Not surprisingly, my parents find this resolution produces too much small detail for their aging eyes. So I set the resolution at 1024x768, which gives acceptable results, except for one thing:
The native 1280x1024 ia a 5:4 ratio, while the 1024x768 is a 4:3 ratio. Consequently, everything on screen is slightly elongated vertically at 1024x768. Not the end of the world, but clearly visible, for example when viewing the big Earth globe in Google Earth
So I tried setting a Custom Resolution in the NVidia Control Panel. 1024x820 is the correct resolution to maintain a 5:4 ratio, and I successfully added it to available resolutions.
The problem is that when I try apply this 1024x820 resolution, it doesn't work. Not only do objects on-screen remain elongated, but the Taskbar and Start buttons disappear somewhere "below" the visible part of the screen. Moving the Taskbar to the side then makes it is vertically truncated.
The obvious fix for this would be to shrink the picture vertically using the On-Screen Display, but I see no control for this. The auto-adjust control in the OSD does nothing except flicker the screen a couple of times. The monitor is connected with VGA cable, as there is no DVI output on the E521...I guess that is why they call the graphics adapter 6150 "LE"
Is there a way to make the Custom 1024x820 resolution be applied correctly to the screen display?
I am not interested in playing with larger icons and fonts at the native 1280x1024 resolution, as my previous experiences with these parameters have never been satisfactory: There are always things on-screen that persist in remaining too small. This is also true in Internet Explorer.
I am more interested in information regarding configuration at the system level, like settings I might have missed in the NVidia Control Panel or hidden adjustements for the display panel.
Thanks.
Thanks.
