I have a Promise Ultra100 TX2, but the activity led light doesn't turn on when I access any of the drives hooked up to the ide card. Anybody else have this card and do the lights work properly for you?
just want to remind you, do not oc your cpu with this card installed on PCI, it may hang your system. I ran into crash when oc my cpu with this card, it seems after oc the PCI (voltage?) has some problem with this card.
The led works for my drives on the onboard ide channels. Does this card need to have the led cable hooked up to it? If yes, any way to hook up the led hook to the motherboard AND ide card?
hmm.. Are there leds with 2 colors? That might be an interesting idea if I can get that to work. I don't have any extra holds to stuff another led into on my case...
Bi-colour LED's share a common leg so I don't think that would be wise. A multi colour LED with discrete cathode and anode leads will work although you will have to decipher the colours displayed --aka psychedelia-- while both busses are busy.
