Hello all haven't been here for a while but I'm not sure what to do about this psu and appreciate your help. I bought this psu few years ago for a back up. Now that I need to use it, I seperated the 4 pin that was connected to the mb connector 20/24 pin. But the problem is the 4 pin connector has round & square holes are opposite on the mb so it won't fit. I checked another mb and it was the same pin holes as the other mb. Now I don't know how to connect power to the mb 4 pin. Is there an adapter? Do I try to cut down one of the other connectors. Do I need to get another psu? tia
Ultra Xfinity 600 Watt ATX
20/24 Pin MB connector .....x1
4 Pin + 12v MB Conector .....x1
4 Pin Molex Connector ........x8
4 Pin Floppy Power Connect ..x2
Sata Connectors ........x4
8 Pin EPS Connector ....x1
