Originally posted by: PCTC2
yes, but it doesn't have a second fan clip. three rubber bands work fine instead. it's a great HSF.
if you want a NB fan, get a thermalright HR-05 SLI (the HR-05 won't fit with a Ultra 120 but the SLI version will) but it depends on the board and VGA card. it probably fits on your P5W but if you have a 8800, it might not. you will want to check out the measurements. and get a 80mm fan for that HR-05.
The HR-05 will fit fine on an LGA775 board at least. The Ultra 120 Extreme can be turned horizontal instead of vertical.
Originally posted by: Navid
I have ordered exactly those two sinks for the CPU and chipset.
So, the only way to fit them is to install the CPU sink rotated by 90 degrees? I was hoping to install it so that it would blow towards the rear case exhaust fan!
Is there no way to install it that way and still be able to install HR-05 also?
Wrong!Originally posted by: graysky
You're kidding about voiding a warranty on a HS, right?
