- Nov 30, 2006
- 96
- 38
- 91
I am building a new Ultimate Photoshop PC now that the system I built just over three years ago is showing its age. I havent been following the advancements in PC technology until now but with a couple Nikon D4s, a need to proccess hundreds of large NEF and TIFF files at a time, plus beginning to do more video, I am looking for ways to speed up my workflow. I have the system designed but am looking for suggestions on hard drive allocation.
I have upgraded to Adobe Creative Suite 6 Production Premium and also use a number of additional editing and workflow programs including Nikon Capture NX2 and Photo Mechanic.
My initial research indicates I need a few fast drives and lots of storage. With the following hard drives, what would be the optimal configuration strategy? Which drive on which SATA port?
My ASUS LGA 2011 Intel X79 based motherboard supports:
Intel® X79 chipset :
2 x SATA 6Gb/s port(s), red
4 x SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
ASMedia® PCIe SATA controller :
2 x eSATA 6Gb/s port(s), red
1 ea. SAMSUNG 830 Series MZ-7PC512D/AM 2.5" 512GB SATA III MLC Internal SSD
2 ea. SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal SSD
2 ea. Western Digital RE WD4000FYYZ 4TB 7200 RPM 64MB Cache SATA 6.0Gb/s Hard Drive
1 ea. Western Digital RE4 WD2003FYYS 2TB 7200 RPM 64MB Cache SATA Hard Drive
Thank you.
George
Below are two articles I found at the top of a Google search;
http://www.zdnet.com/blog/hardware/b...p-cs6-pc/19985
A Photoshop system needs masses of storage. This is not just because the application itself is huge, or because the output can be massive. It's because in order to get the best from Photoshop you need multiple drives, with each one dedicated to handling a specific task.
Ideally, you need four drives. One for the OS, one for the application, one for your output files, and one to act as a "scratch disk." A "scratch disk" is what Adobe calls using a portion of a hard drive as virtual memory. You can get away with fewer disks, for example two disks -- one for Windows and the applications, the other to ask as storage and a "scratch disk" -- but it's far ideal. Trying to run everything on a single disk is best avoided as it's going to create a significant performance bottlenecks.
Since this is an "Ultimate" system, I'm going to recommend that you use four disks. You'll need two large hard disk drives (HDD), and two fast solid state drives (SSD). You'll install Windows onto one of the hard disk drives, and Photoshop onto the other hard drive. Then you'll use the one of the solid state drives for your output files, and the other as a "scratch disk." This setup gives you the best possible storage performance, eliminating a number of potential bottlenecks.
It's worth noting that you don't need big solid state drives for this build because they're only used for short-term storage. Once you're done with a project, it's a good idea to move the files to a hard disk drive where the cost-per-gigabyte is much lower.
http://robertoblake.com/blog/2011/07...-cs5-computer/
Super Photoshop Hard Drives .
You are going to need at least 3 Hard Drive Leves, here is how Ive broken it down:
■Application Level > Windows OS, Photoshop, Other Applications: 1x 1TB Hard Drive (2 Partitions)
■Storage Level> All files and data from applications: 2x 1.5TB Hard Drives
■Scratch Disk Level> Dedicated Scratch Disk: 1x 9 GB Solid State Drive
So why are we using 3 Hard Drive levels and 4 Hard Dives (minimum)? Photoshop performs faster when it multitask across these different drives and use their separate bandwidth. So having your application, files, and temporary files, all on separate disk using separate resources is essential to maximum Photoshop Performance. Solid State Drives for the scratch disk take that performance to a whole new level. Also if you are doing major work like we talked about you know that it is possible to get a 1GB or larger Photoshop file, the max file size for PSD is 2GB, you can exceed that in a PSB, not that I would want to
Thank you.
George
