Has anyone ever used one of the ultimate hard drive coolers from a site like 3dcool.com???? If yes, I am wondering how you like it and obviously if it works like they calim it will. Any info is appreciated. Thanks
I used to use them before I bought my removeable racks.
Worked quite well. The entire length of the thing is a heatsink that screws up real right to the top of your hard drive. (spring-loaded screws) 2 fans in the front blow across the heatsink. Much better than the cheaper type that just give you 2 fans to direct onto your drive.
