Argh, decided to try another ROM.
So far, it's very fast with the 3D app tray and live wallpaper using a modest overlock (800MHz).
Minimal lag the first time you open the tray, gone after that. Some apps don't seem to coexist that well with it. When you back out of an app, sometimes it leaves a black square in the middle of the app tray that goes away once you hit home.
I don't know if it's worth switching if you just installed a ROM. It's more like I wish I had gone with this one prior to Smoked Glass and the others.
BenchmarkPI: 3200-3500ms
Edit: 3d launcher does not work in landscape. "Seems" to run a little warmer than smoked glass.
