Uh oh! Whining sound?
I'm hearing a whining sound that seems to be coming from my computer, I have a WD 120GB HD with the 8mb cache.
My DVD drive isn't spinning so I don't think it's that. I turned my speakers off and nothing else in my room besides the lights are on now or moving.
It could be from a fan in the case or something too. Also, the sound just went away 😛
Gently push in the hub of each fan to slow it a tad and see if the whining stops. If it does, you've found the problematic hardware. If it doesnt, disconnect your hard drive and boot into your BIOS, wait a bit, see if the whining continues. If it doesn't, it's your HDD :thumbsup:
What does booting into the BIOS do? Keep optical drives from spinning?
There is a good chance it is just a fan. The smaller fans seem to go pretty quick. In the height of my DC days, I was running 8 A7V133's (among other boxen). Each chipset fan took turns dying on me. They would whine, and or scream from one to three months before quitting altogether.
I resolved the issue by replacing the chipset fan with a larger heatsink only solution (which was also much quieter). That was a pain because I had to remove every board from the case (no removable MB trays) to pop the fan off from the back of the MB.
AFAIK the easiest way tp prevent optical drives from spinning is not to load any media. 😛
Otherwise follow MrK6 advise
I was just trying to think of a way to run your PC and fans for awhile w/o having the HDD connected... is there a better way?
