Ugh. Want to throw computer.
Gibson486
18,378
so....did you just take the most solder you could fit into those joints? It looks you took melted solder and dumped it on.
TridenT
16,800
45
Uhm, no. I used as little as would hold it to be honest. It looks like a lot, but it ain't for the three that are near each other. I need the wirey stuff that sucks solder up to get it to be any less.
TridenT
16,800
45
Giving up. I've tried hard. I can't do it apparently. There must be some kind of contact between the points or something that I just can't see with my eyes.
ahenkel
5,357
what does it matter? The laptop manufacture probably bought it from the same place.
Oh it'll matter I've fixed a couple laptop jacks and have made the mistake of not using at least half way decent jacks. Even with them perfectly soldered in I still had problems with bad connections and shorts.
TridenT
16,800
45
Let me guess you bought the new jack from some ebay seller in China for 3.50 and that included shipping.
Dude. I totally did and the shit took nearly 2 months with the first one to get here so I emailed them. They sent me another. One of them actually can fit the plugin for the powerjack. The other can't.... WTF. They looked really similar so I never tested.
I just removed the one that didn't work. (Every time I plugged it in there were some sparks that I saw)
This other one is useless because the diameter is too small. wtf....
God damnit!
grrl
6,204
I was gone a few days, but it's nice to see nothing changed while I was away. Trident still sucks at life and then whines about it.
pcgeek11
21,595
4,666
Looking at those solder points, I'm not shocked that it doesn't work. It looks like someone ate some solder then threw up on the board. :p
You don't need to have a solder wick, a quality solder sucker (ESD Safe One) should have cleaned that right up with a good iron and a steady hand. If you didn't use an ESD Safe solder sucker that might be where the 10,000 volt surge came from that zapped the board. Hmmm
http://www.static-esd.com/anti-static_solder_sucker.htm
http://www.uxcell.com/desoldering-pump-solder-sucker-with-anti-static-esd-safe-tip-tool-p-19468.html
lxskllr
57,926
8,188
The soldering iron isn't the problem here. Take the jack out, clean it up, and try again. Either you fucked up the installation, or the jack's bad. Hopefully you didn't burn anything out when you plugged it in. I'll tell you what won't fix it, whining on AT. That might make you feel slightly better for whatever reason, but it just pisses everyone else off.
