Ugh, the sad state of big-box pre-built desktops. (Atom / Kabini)
jason166
56
OEMs selling systems factory overclocked was the original worry that caused Intel to specifically lock overclocking down on OEM channel CPUs. At that time, market segmentation was mostly about binning and CPU frequency though I still would not expect Intel to switch gears with this, as allowing OEM overclocking introduces reliability issues, and breaks their market segmentation efforts.
Do you think that with the appearance of the G3258, and non-Z overclocking, that we will see OEM boxes with H81 chipsets, and G3258 CPUs, that are either pre-overclocked (4.0Ghz should be a walk in the park), or advertised as overclockable?
Or do you think Intel intended that part to be an enthusiast / retail-only part, not for OEMs, and that if OEMs started to offer pre-overclocked systems (I'm talking major brand OEMs, not boutique system-builders), that Intel would scale back their selection of overclocking / overclockable CPUs?
crashtech
10,573
2,145
Yeah, though one would hope they might start bringing up the clocks on the lowly dual cores a bit moving forward, this would help to differentiate performance of newer CPUs a bit, as of now you'd be hard pressed to tell between the last 3 gens of similarly priced CPUs aside from benchmarks.
NTMBK
10,297
5,289
So cute! I'll take two, please. Hopefully, they will prove to be faster than the C-70 NanoPCs.
Wonder how slow the eMMC is? Or if you can boot off of the SD card slot? (Put Linux Mint 17 on an SD card, and boot if that way, and leave Win8.1 on the eMMC dormant.)
It would be a shame if the eMMC is dog slow- hopefully someone will get one and do some testing on it. Though you can get USB3 memory sticks which are very fast these days, so that's an option too.
cbn
12,968
221
It would also help differentiate the desktop better from the laptop.
Example: I have a G1620 Celeron desktop chip, but how much faster is that chip from even a moderately priced laptop chip? (I think they are probably too close together in performance)
I think we are probably at the point where even the stock clocked Celerons and Pentiums should be 4+ GHz.
ElFenix
102,353
8,444
.....And that is sad too.
And probably a sign of the poor value we see in budget desktop these days.
But I think change is looming on the horizon. (Pentium G3258 is an encouraging sign of progress for value chips)
A8-7600 is not a bad concept for Pre-built either, though DDR3 1600 will hurt performance. I only wish the price would drop on those. (Too bad the GDDR5 thing fell through for AMD and they got stuck with such a large die for Kaveri)
poor value? i got a haswell i3 with more hard drive than i'll ever need for office tasks for $400. what's poor about that? the only thing disappointing was that i can't get samsung magic ram from microcenter for $17 anymore.
the only thing that may be coming is maybe we'll see the revenge of acorn computer.
but that's the case even at the highest end. bringing up the clocks at the low end isn't going to help because you'd still be hard pressed to tell between the last 3 gens of similarly priced CPUs aside from benchmarks. there isn't an office task out there that a sandy celeron can't handle with ease, so it doesn't matter that a broadwell/skylake celeron hits even higher clocks.
Maximilian
12,604
15
Prebuilt? Dosent matter if it has an overclocked octacore with 64GB of memory and quad SLI... they will still load it up with junkware that brings it to a crawl.
cbn
12,968
221
Pre-built budget desktops are not a poor against budget DIY desktops (which in my opinion need a lot of help from Intel these days.....pentium g3258 helps a lot though).
...but rather these pre-built desktops (particularly celeron and pentium.....especially atom based ones) are a poor value compared to laptops IMO.
Ideally, I would like to see consumers want to buy both budget laptop and desktop.....instead of thinking to themselves that their laptop is almost as good as that Celeron or Pentium SFF desktop on the shelf.
monstercameron
3,818
peace of mind with a warranty can be a factor.
VirtualLarry
56,542
10,167
That was the conclusion that I came to as well. I figured that for $150, an Atom desktop was a poor value, considering that I was able to get a complete N2830 laptop, with screen, etc., for only $230.
Edit: OTOH, if the desktop PC had a Haswell i3 3.4Ghz in it, for $400, that would be a much better value, relative to a laptop, because laptops generally have mobile or ULV CPUs in them, and don't have the TDP headroom, and thus the performance, that desktop CPUs do.
OBLAMA2009
6,574
I was at my local Staples store, and there is a coupon for $100 off clearance computers until Aug 30. They had two desktop PCs listed, one for $249.99, one for $279.99.
Edit: Those were the CLEARANCE prices, list prices stated on the sign was $399.99 ea, I believe.
I was surprised that no-one picked them up for $100 off already. Then I googled the specs.
The $249.99 Dell was a J1800 Celeron (Bay Trail-D Atom). The $279.99 one was an HP, I think, with an A4 in it (small core).
Although both were quad-cores, they just didn't seem powerful enough to waste $150-170 on.
The "race to the bottom", including the introduction of Atom / Kabini into desktop PCs, sold for as much as $400 list (4GB / 500GB), is also partially what is killing the desktop market.
Along with the stagnation of the higher-end Core CPUs as far as absolute performance goes (and how much does 10W of power consumption matter on the desktop? Not a whit, to most people).
If I were an average desktop user, and my PC was five years old, and I went into a store and purchased a brand-new budget-class PC, and found out that it was in fact SLOWER than my five-year-old PC, I think that I would be turned off of desktop PCs forever.
I can understand Atom and Kabini / Beema in laptops. Power-consumption is king there, as long as you have adequate or better performance. I don't fault Intel or AMD for pushing their small-core lines there.
But desktops? What garbage!
I would rather have a five-year-old Walmart-special desktop, with 4GB of RAM (removable, not soldered in), and an AMD Athlonn II X2 250 rig, than a modern Atom rig, even with quad-core. (Because the Athlon II has superior single-threaded performance.)
their bag of tricks is empty so a couple of years ago they began trying to reset the low end even lower with all this atom scheet and also obscuring what youre buying, renaming atoms "celeron" and "pentium", not stating clockspeeds or generations, introducing confusing numbering schemes, lowering clockspeeds significantly and still calling stuff i3 and i5. i just stopped buying new stuff, although one of my machines just died so im in the market again, but ill never be a hobbyist again
heres a bangin axe bargain on a board/cpu: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1816185
nyker96
5,630
too bad to most people a quad core = any other quad core. there would be no difference to these people whether you talking about a quad atom cpu, or a quad 4670K haswell. well to these people, they prob got no defense against been tricked into buying a new "quad".
taltamir
13,576
I remember when i bought an atom netbook (3rd gen atom) at costco. something like 90% return rate because it is such crud. so they actually made sure there are people there explaining to you that it is going to be slow.
of course, I didn't realize "slow" would be 10 minutes to open MS word. Never bothered with this junk since.
The desktop market isn't "dying". it is still the largest market and its still growing. it is just growing significantly slower than laptops, but this trend will NOT continue because:
Ok, that isn't entirely accurate, its also because people compare "mobile devices" and "desktops" instead of seperating mobile devices into netbooks, notebooks, ereaders, smartphones, etc.
I have a laptop, desktop, ebook, and a smartphone. According to this improper grouping I have purchased 3x more "mobile devices" than desktops. even though they each have a completely different purpose
For that matter, those who claim desktop is dying use the same tactic in gaming comparisons. Comparing desktop to all consoles put together. even though the xbox has more in common with windows than it does with the playstation or the wii
VirtualLarry
56,542
10,167
I have a friend and a tech-support client that has / had a small Atom Netbook that they showed me a few years ago. They turned it on for me to show me, and it took like 15 minutes, literally, to boot XP starter. I think that it had 1GB of RAM, and like an 8GB SSD or something almost like an SSD, but slow.
I was kind of like, this is a neat sized device (all 1024x600 of it, not even 768 vertically which can cause issues with some apps), but man is it slow.
A year or two ago, I picked up my first 11.6" laptop, a pseudo-netbook, from Acer. An Aspire One 722. C-60 APU, 1366x768 resolution, 4GB RAM, 250GB HDD, Windows 7 64-bit. It was actually a pleasure to use, compared to that old XP Netbook(tm).
I upgraded it with a 120GB SSD, and it got even better. Unfortunately, it hasn't aged well over the last two years. It still web browses OK, even with MSE installed. But Skype kicks the Brazos APUs' asses now, chews up most of the CPU, leaves little to nothing left for other tasks.
I have another friend with a nearly identical model, only his has the 2GB RAM and 320GB HDD. He can't stand his. I told him I would give him an identical 120GB SSD like I have in mine, but he hasn't taken me up on my offer yet. I offered to buy it off him too, if he wanted to sell it. He likes having a 2nd backup PC though, in case something goes wrong with his main desktop. Totally understandable.
The problem with today's modern "budget" desktops, is that they are using these netbook chips in full-sized desktops. What madness is this.
Imagine if all desktop PCs, back when the original Atom-based 1GB RAM Netbook came out, were as slow as those Netbooks, taking 15 minutes to boot. The desktop market would have slumped back then, just as bad as it is now!
Oh, and those saying that the desktop market isn't dying, that's only because of corporate desktop sales due to XP being EOLed, so they had to buy new desktops with Windows 7. And you can bet that they aren't buying the bottom-feeder Atom-based desktops either.
taltamir
13,576
Oh yea, the literally 15 minute startup time is awful.
i see it more as a benefit than a problem. i remember when atom prices caused ultralight notebook prices to fall from from ~1500 to ~500 almost overnight. and they stayed reasonably priced since.
Also, an atom in a desktop format is called a nettop.
Sure, you could say its one big scam and hurts consumers. but what is new under the sun? scams always existed and at least this is an easily identified one.
The biggest problem with atom is its ram limitations. early ones were limited to 1GB of ram, newer ones to 2GB. this is ridiculous. I routinely run out of ram on my 16GB desktop.
My work laptop has a pathetic 2GB of ram and I can do ZERO multitasking on it because otherwise it just locks up from thrashing. I had to remove the anti virus from it and disable graphics and remove nvidia experience (neat driver auto update) and basically hack it down to the absolute bare minimum to even make it run one 2GB of ram... and its still constantly running out. 4GB is the absolutely bare minimum in 2014. And I would recommend that everyone get at least 8GB
VirtualLarry
56,542
10,167
Not unless it's in a small cute case that hooks up to your TV. If it's in a standard-sized tower, I call it a desktop, even with an Atom CPU. Those are the PCs I'm primarily complaining about.
I had forgotten about that. I guess I'm going to check Intel's ARK now, for the N2830. I posted a review to BB about my laptop I purchased, and claimed that it had 4GB fixed RAM amount, and someone responded in a comment and claimed that you can, in fact, upgrade the RAM to 8GB. Which would be really nice.
Oh, I vehemently agree! My P35 boards from 2007 have 8GB (maxed out). My Thuban rig, and a relative's G1610 rig each have 16GB of RAM. I much prefer motherboards with four (or more!) RAM slots. Two is pretty limiting. (Have to pay for 8GB sticks.)
taltamir
13,576
Oh, now that IS irking. I haven't seen those before but it sounds like a very clear cut scam attempt. where they try to trick people who have been warned about nettops.
Roland00Address
2,196
260
I love these processors in small form factors. I wish they make small form factors for the desktop as well (we call them cheap home theater pcs that connect to your tv)
But it is CRIMINAL to put any of these cpus in a computer the size of a cereal box or bigger. (a cereal box is roughly 12x8x2.5 to 3 inches). Those slimline pcs that have been around for 7+ years with a normal dvd drive are roughly 13x10x4.5 and these normally have cpus that are in the 80w tdp range and less, and they can be fine with a very small video card like sub 30 watts.
Why the hell do I need a cpu that has a 10, 15, or 25 watt tdp, no graphics, and peripherals in a case that could easily fit a 125 watt cpu and a 150 watt video card with no extra cooling (this is what prebuilt oem "normal size" cases are capable of)
Personally I think said people that make these oem boxes with cpus that do not fit should be shot. It makes me that angry, just put them in a firing line and die. You are the reason why the desktop is dieing.
This computer is 10.7” tall, 3.9” wide, 14.8” deep and can easily fit a normal cpu
Roland00Address
2,196
260
they do make them in small form factor
http://www.amazon.com/s/ref=nb_sb_no...eywords=nettop
and they are pretty awful in that form factor too.
Yes I know, note that is the awful 32nm clovertrail generation, and that prices I do not believe includes an OS. I used to sell computer I know how overpriced the OEMs made these small computers when in reality it is cheaper for them to make it small vs those big expensive boxes. The MSRP of these type of computers with OS should always be sub $300 and really sub $250 and this is before sales and such.
as someone who's been shopping for a desktop the last two weeks, i totally agree. J1900 is a joke for desktops especially at $300. It's essentially the same as the original atom netbooks that came out a few years ago. everyone was ranting and raving about how good they were, except that they sucked for what they were trying to do.
Not even close passmark scores for simplicity sake. Still dog slow but much an improvement.
32nm pineview d550 (old architecture with die shrink)
Single Thread 226
Multi Thread 512
22nm silvermont J1900 (newest architecture non tablet model but easily netbook tdp)
Single Thread 532-235% so that is an increase of 135%
Multi Thread 1922-375% so that is an increase of 275%
45nm e8400 core 2 duo at 3 ghz (stock)
Single Thread 1257
Multi Thread 2163
So the old e8400 is only about 13% faster for multi thread but for single thread it clobbers the nettop cpu being a 136% faster. The nettop cpu has a vastily smaller tdp and has built in graphics
The real problem is the hard drive instead of ssd, the oem bloat, and the windows software bloat (put something like android or linux and it will run much better, windows has so much power that software designers do not try to debloat). Furthermore limit the amount of threads that are running in the background by non active programs.
But hey that is no longer a windows pc anymore, that is just a phone that is projecting to a tv. Windows pcs can be awesome, but it is hard for them to be awesome while being cheap, the cheap stuff is meant for different paradigms or the people who have the ability to not claw their eyes out for something is dead slow.
NTMBK
10,297
5,289
Is it really, though? If you put two big desktop boxes next to each other in a store, both of them have a "Pentium", but one of them has four cores and is way cheaper! Which one do you think the general public will buy?
