- Sep 10, 2001
- 11,711
- 8
- 81
Ihave a system which has a 36 gig SCSI hard drive which I used as primary drive (place where OS installs to) and then later I added a SATA drive (SATA ports are onboard, the SCSI had to come via a PCI card). Now I'm trying to reinstall a fresh copy of XP on the system and when I went into Windows Setup it showed the SATA drive as D: while my SCSI drive as C: (even though at the time windows was installed on the SCSI one and it has always been the C: )
anyway, I didnt think much of it and thought it would just be extremely annoying later when I install do have windows on D: but whatever. Now the setup finished its initial phase of formatting the drive and then copying some files but on the first reboot it fails. Says BOOT DISK FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. Probably because it's looking in the SATA drive not the SCSI one which it just installed to...
When I open BIOB and go into the Hard Drives section of Boot, it shows both my drives and the SCSI one is listed as #1. So WTF is windows keep thinking the SATA is C: and how do I remedy this?
Cliffs:
1. formatted my pc which has a scsi drive and a sata drive
2. installed windows xp to the scsi drive (was given D: in windows setup)
3. now wont reboot anymore- says disk boot failure... probably because its looking in the C: ?
Cliffs:
