UDF Read Utility
aviwil
I wrote a DVD Data Backup using Burnaware 3.0 Beta under Win 7 . It completed and verified succcessfully . I've tried under Win 7 and Vista , but I can't read it . I did succeed with IsoBuster to see the files as UDF , but to actually copy them , I need to purchase it , and am not sure it will even work . I saw something called Adaptec UDF Reader , but it didn't install right in Win7 or Vista . Can someone recommend some free utility which will be able to extract the files ?
Thanks .
UDF is a filesystem, not file format, and Windows has supported it out of the box since XP. If the disc isn't reading, you have another issue.
Well, I remember having to use a Toshiba UDF driver to read some discs in the early days of XP. Maybe native support was added in one of the Service Packs. Anyway, Vista and Windows 7 should definitely have built-in native support.
Have you checked with Burnaware support? If Burnaware can read it, you can try to make a disc image file, then mount that as a virtual disc with something like Virtual CloneDrive or Daemon Tools.
I usually use ImgBurn and ISO + Joliet + UDF 1.02 filesystem for all my data discs. I never have a problem reading them (except for rare bad burns).
I don't know of a good, full featured alternative to IsoBuster.
Like any other filesystem, there are multiple versions with varying features so it's not a black and white thing. But XP does have UDF support.
http://support.microsoft.com/kb/321640
http://en.wikipedia.org/wiki/Universal_Disk_Format
