we have several problems here.
I was looking on the ubuntu forum and bug-tracker, and the SAME issue is known for months already, because i saw entries
saying x-server unable to start with Radeon cards from may. Thios bug affect most/all newer radeon cards as far as i saw.
Now we have october.
All the helpful "hints" about installing upgrades or whatever....we just have a problem there:
you CAN NOT UPDATE any files or drivers (assuming such updates even EXIST) while running off a live-cd, what should it update ?
Files on ram-disk ??
So..i come up with the glorious idea there MUST be a way to just boot into that ^!%%!@$%!@ ('scuse me) by chosing
"safe graphics mode" from the install menu.
FIGURED if i do that i might get a screen with an option to INSTALL this system, even if the x-server is not running, and then try to update or edit xorg.conf on the installed system.
PROBLEM only...when i chose "safe mode" from the live-CD i get a BLACK screen and no display at all. <----
cliffs, to recap my experience with "ubuntu"
() does not even boot off CD since x-server fails to start
() people give tips like updating and editing X configs
() problem is, the system is not even installed on HD, so "updating" and editing configs can not apply.
() even if i edited config-files in ram and WOULD be able to bring up a working x, would starting X then come up with a desktop with self-explaining options to install/update ? Because i dont know what the boot/installer would do if it would not abort as it does now.
() "safe graphics mode" does not work AT ALL, blank screen, no display
() research shows that this issue w/ the x-server and radeon cards is existant for a long time already.
