- Mar 11, 2000
- 24,045
- 1,673
- 126
I had Ubuntu 17.10 installed and it seemed to work fine on my Core 2 Duo 2.4 GHz MacBook 2008 with Intel 330 SSD and 4 GB RAM.
So, I installed the final release version (coming out this week) of Ubuntu 18.04. This is a brand new clean install and while it works fine, trying to load up system settings takes eons. For example, if I go to Activities and type in "Time" to load up the Date & Time setting in Settings, it takes literally over a minute to load. I just timed it and it took 63 seconds. In contrast, Firefox loads in under 5 seconds, and the default home page is loaded at about the 10 second mark. Files loads in just a couple of seconds.
I loaded up System Monitor to see what happens, and it just is locked up during that period when Time is trying to load. I can't do anything at all, and neither can System Monitor.
I think I might have to go back to 17.10 for now, if there isn't an easy solution for this.
