Ubunto 11.10 help
Rhybius
Hello all,
I hope this is the correct thread for this post, if it is not I apologize and ask one the moderators to place it in the correct thread. Here is my problem, I am running Ubuntu 11.10 on my old Acer 5315 laptop. ( 2 GHz, 1 gig ram, 100 gig hd, just an bargain basement laptop.) Anyway, I digress, after I installed Ubuntu my CPU fan will not run once the OS boots up, it runs during the start up and if I open my bios, but as soon as Ubuntu loads it turns off. Obviously my computer overheats and shuts down. I have looked around and found a fix to run in terminal to correct the problem, but I am having trouble getting it to work. Here is the steps and process I have tried:
You have attached the modified version of acer_fancontrol.
Here is the readme:
1) Download the script
2) Change the directory
Code:
cd Downloads
3) Unpack the script
Code:
tar xvfz acer_fancontrol.tar.gz
4) Change the directory
Code:
cd acer_fancontrol
5) Pick the memory size which matches your memory size(it doesn't matter if the model isn't the same).
Code:
gedit acer_fancontrol
You can use other text editors too.
The options are:
- 512 MB : delete the # from the beginning of the 77th line
- 1 GB : delete the # from the beginning of the 79th line
- 2 GB : delete the # from the beginning of the 81st line
6) Install the script
Code:
sudo cp acer_fancontrol /usr/bin
sudo cp mempat /usr/bin
7) Make it run automatically
Code:
sudo gedit /etc/rc.local
I have tried it several times and I still cannot get it to work, I keep getting an error that says the files does not exist or cannot stat because directory does not exist etc.
Any help, suggestions or showing me what I am doing wrong would be greatly appreciated. I am new to Linux and I really want to get this to work. Also not sure if I need to update my bios and I cannot find how to do that with Linux.
Sorry for the lengthy post and I would like to thank you in advance for your time and any suggestions.
Sincerely
Rhybius a lonely Linux user in need
What step do you get to? The error your getting is saying you're working with an invalid directory.
sounds like you aren't working from the right directory. You should be in acer_fancontrol(directory) when you copy acer_fancontrol(file) to /usr/bin
Ok, so I went back and tried everything from square one, this is the error I get in terminal after i run the script sudo gedit /etc/rc.local
(gedit:3407): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.M8HO7V': No such file or directory
(gedit:3407): Gtk-WARNING **: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
A quick Google says there's some flakiness with gedit and permissions. Try this instead. I don't know why it would work, but who knows?
gksu gedit /etc/rc.local
Do you have the fan issue when you boot from the Live CD? If not, can you edit and install the script while booted from the Live CD?
You'll have to manually mount the hard drive, eg:
Code:
sudo mount /dev/sda1 /mnt
(replace sda1 with the correct partition (sda2, sda3, etc), but sda1 is most likely correct)
Follow the instructions for acer_fancontrol, except for:
(6) install the scripts to
Code:
/mnt/usr/bin
and (7) edit the file
Code:
sudo gedit /mnt/etc/rc.local
