I have a "husky" air compressor that I'm attempting to rebuild as I found the internals to be very dirty. I mostly started working on this because it wouldn't run anymore and found the culprit to be a faulty switch. But before I found the switch to be at fault, I took apart the compressor assembly and found a lot of dirt due to there not being a filter on the intake. So anyway I have the piston out and I cleaned up the piston, the ring and the cylinder with rubbing alcohol, removed some particulate matter and I'm done. So now I'm wondering, what kind of oil should I put in here to lubricate it?
This is technically a maintenance free air compressor, so I don't exactly know what the difference between an "oil" and "oil free" air compressor is except that the prior you don't have to add oil. Do they for the most part use the same oil? Can I just use 5w-30 motor oil in place of the compressor oil?
Update: I've fully reassembled the air compressor and I tested it up to 5 psi, seemed to run smoothly. However I don't have any air tools so I didn't feel comfortable in bringing the compressor to 100psi and or doing continuous testing so I don't know at this time whether or not it will hold up.
Now that I've tackled that project, onto the next one. I have a Diehard battery booster, portable power and compressor. http://www.sears.com/shc/s/p_10153_1...&blockType=G15
Well one day when I was inflating the tires of my truck, I hooked it up and left it alone for several hours (forgot about it) and the compressor stopped working. Everything else worked on it except the compressor and so, after further visual inspection and finding some oil on the bottom of the unit, I concluded that the compressor had seized. Since I really only needed the compressor that comes with this unit, it has been useless to me since it stopped working in 2008. So flash forward to today when I "completed" (we'll see!) work on a broken air compressor, I felt like I had the ability to tackle this looming project of mine. Alright, so I took the unit apart, took out the compressor assembly and I was able to confirm my suspicions, the compressor was completely seized. So I took the compressor apart and I found a bunch of metal shavings on top of the piston and inside of the cylinder.
Alright, so this is the real crux of the problem, something that might affect BOTH compressors. The Designs of BOTH air compressors are almost identical, the difference on this second air compressor that I've found is that it's covered in oil on the outside (leaked). I think the reason why my compressor failed is because it got too hot and all the oil left the compressor, causing it to seize. I didn't find evidence of any oil actually on the first compressor but this second one looks like it has oil like I would expect it to. Keep in mind that the first compressor wasn't having any problems, it was just that since I was already in there, I figured I'd clean things up and attempt to bring it to "like new" condition.
So now I'm wondering, how should I lubricate this compressor and what should I do? Maybe this is an older design that uses oil and has no teflon coating on the cylinder walls, therefore that's the reason why it failed? That maybe I could clean things up and try applying that same teflon stuff myself? I'm not really sure what to do now.
