Tyan Trinity 400 (s1854) owners what chip are you running??
frover2000
371
For future upgrading purposes i'm curious as to what chip your S1854 is running. Also the motherboard revision and batch number F,H,J etc. yours is.
Thanks
BGTGRGKG
19
I have 3 of these boards all running good #1 is rev.c gotta 633 celeron #2 is rev d its running a pII 333 slot 1 and last rev j running 600e flip chip all are running good with out a problem all have latest bios at 1.07 .
Smellfunny
17
I am running Rev. D and I have a celeron 466 PPGA in it. I have had really good luck with my s1854. My friend has a first run of the tyan s1854 I guess it would be rev a (?) and it has been nothing but headache for him. But they changed it since then. If I could get a t-bird in it I would keep mine.
But I have sold it all mb/processor/video card and today fedex should bring a box with an ABIT kt7 raid, a 20 GB HD and a 1.0 ghz t-bird. :p'''
lobe
202
Rev. C with a slot 1 PIII 800mHz/100fsb chip. Pretty fast and very stable.
Vrangel
1,259
It will take pretty much anything.
Currently I have c600@900 on my TT400-B (MSI slocket).
Using 1.00 BIOS which says its P3-900. :)
Stable , I didnt have to reformat HD since I installed
this mobo a year ago. Back then I had c366@550.
techg
28
im not sure what rev...PIII 500@560, excellent board, stable, no problems though.
pulse8
20,860
Also not sure what revision. PIII 600@800 with total ease and stability with stock HS/fan. Great mobo.
David
ronach
I have a rev (C)&(D), running at 750 & 933 respectively, using a 500e and a 700e. I've had the usual computer problems as everyone else has, but I really can't fault the boards for any of them. Using Bios rev 1.00 on both.
ronach
buckeye
330
Vrangel,
I am also running my Celeron 600 at 900 MHZ, using MSI 6905 slocket. I had to bump the voltage to 1.75 from the default 1.7 V. I cannot read the CPU temperature as Tyan S1854 doesn't offer mobo monitoring. I was just wondering what cooling system you are using for the processor. I am just using the retail HSF. It is very stable though, but I keep the case open for proper air circulation, just in case. Could you please recommend a good cooling for my CPU? Thanks a lot. Also, is there a way that we could read the CPU temperature?
