Tyan Tiger MP Problems
JK200
I am at a loss, I can't get my system to install Windows2000 without blue screens.
I have replaced the motherboard, returned 18T Crucial memory modules for 18T4, swapped Enermax EG351P for EG465P, Replaced 1 of my 2 CPUs, tried a Matrox G450 AGP and ATI Mach64 PCI Videocard instead of G550. Took out all but 1 CPU, 1 256MB Mem Module, 1 HD and 1 DVD Drive. NO LUCK
Anyone have similar experiences?
Here are the specs:
Graphics Workstation
blah that sucks i cant give u any really good advice uve already done everythign i would have tried
i still suspect its the ram though
put the most conservative settings possible in bios (realizing u dont have many options there ...)
What BIOS version ar you using? and disable ECC in BIOS that may help. Do your XP's show up as MP's in BIOS? You should be using 1.03 BIOS revision - I'm using 1.03 Beta and it rocks!! Using 2x1600XP's and a Gig of Registered Crucial DDR as well. SBLive & GeForce2 Ultra and running Fibre Channel & having no problems now.
