Tyan S2380 HELP
DragonFire
While I understand the S2380 is old (Slot A) I hopping someone can help me out with a little problem that is rather annoying.....
At the moment the computer is running Windows XP, however I had this same problem under Windows 98 SE.
The Problem: When telling Windows to rest or to shutdown the computer just doesnt do it. It doesnt rest the computer and all you see is Windows shutdown screen and when telling it to shutdown, all you see is the windows is now shutting down screen. The computer doesnt lockup since the caps key still works. I'm using the lastest bios and Iv tried the lastest VIA 4in1 drivers and nothing.
I hopping to sell this computer but if you have to use the rest/power button to rest it and turning off I'm not sure if I will be able to sell it.
Can someone please help me??
Thanks!
