I want to upgrade my radio in my car to a different factory radio. The pin connectors are identical except that the steering wheel controls operate on different voltages as the upgraded radio has handsfree telephone controls, and the base one doesn't
I want to convert the inputs from my steering wheel controls into the voltage levels that the upgraded stereo would understand
The steering wheel controls has two outputs, they are referenced to ground
The upgraded ratio has two inputs also referenced to ground...
I want to build a 2 input 2 output box that goes inline w/ these two wires
It should look something like this:
http://img104.imageshack.us/img104/2831/untitledbu7.png
Here is the preconditions
1) For the two inputs, they are at 5V when no buttons are pressed
2) the two outputs should be at 3.3V when no buttons are pressed (ie when 5V are coming in on both input lines.
Rules:
1) Vin1 = 0.75V and Vin2 = 5V , Vout1 = 0.7V and Vout2 = 3.3V
2) Vin1 = 5V and Vin2 = 0.75V, Vout1 = 1.3V and Vout2 = 3.3V
3) Vin1 = 2V and Vin2 = 5V, Vout1 = 3.3V and Vout2 = 2V
4) Vin1 = 5V and Vin2 = 0V, Vout1 = 3.3V and Vout2 = 0V
5) Vin1 = 5V and Vin2 = 2V, Vout1 = 3.3V and Vout2 = 1.3V
6) All other unspecified input combinations, Vout1 = 3.3V, Vout2 = 3.3V
I haven't taken EE in a long time..what kind of system do I need to build? Where to start researching?
Rules:
