Two-Factor authentication should be used as an additional layer of security for your accounts, but it is not a replacement for following best practice in regards to password selection, length, complexity, not re-using passwords, etc.
You should still use a long, hard to guess, and hard to brute-force, password for these accounts. You will be happier you did if the day comes that a vulnerability is found in one of the two-factor implementations you are using.
