Two Samsung 840 Pro's & 1 840 have failed, 4 at [H]ardOCP (Early review sample SSD's)
Discussion in 'Memory and Storage' started by videoclone, Nov 8, 2012.
Thread Status:
Not open for further replies.
  1. fov001
    fov001 Junior Member
    Nov 15, 2012
    24
    Newbee question....will the RAID0 x2 128GB be faster than a single 256GB for this model???
  2. fov001
    Nov 15, 2012
    24
    I Know RAID0 is faster than a single drive but the 256GB version of Sammy 840 Pro has significant gain over the 128GB
  3. Fernando 1
    Fernando 1 Senior member
    Jul 29, 2012
    330
    Yes!
  4. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    Depend on the drive, mobo, and drivers it can go either way; especially if it is a drive that loses significant performance from lack of trim. SSDs have built in load balancing which increases speed as drive size increases. There is also a question of connector (is there a SATA bottleneck which can be bypassed via RAID)
    Also, did intel release the RAID0 trim driver already? IIRC they haven't yet and when they do it would only be for latest gen mobos.
    #179 taltamir, Nov 19, 2012
  5. Meghan54
    Meghan54 Diamond Member
    Oct 18, 2009
    7,737
    621
  6. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
  7. Engineer
    Engineer Elite Member
    38,335
    181
    IIRC, all of the 11.xx series have TRIM support when paired with an 11.xx OROM version AND a Z77 board (no support for other chipsets just yet).
  8. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    I bet this is intentional. Why give out free features to older boards
  9. Engineer
    38,335
    181
    Dufus has a thread on the board in which he has "modified" a few bytes of the OROM to allow a P67 board to work. Just waiting for him/her to spill the beans! :biggrin:
  10. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    Well then, that is proof of the matter than. it is driver based DRM just like with the nvidia drivers. I bet it would be possible to make cracked drivers that would work without need to modify the orom at all
  11. Dahak
    Dahak Diamond Member
    Mar 2, 2000
    3,717
    23
    Hmm wonder how long it will take to get the update. Been eying one at ncix as it come with ac3 free as well.
    seen anand's waiting on some last confirmation here
  12. videoclone
    videoclone Golden Member
    Jun 5, 2003
    1,465
    So 830 vs 840 ? .. what are you guys going to buy?
  13. jwilliams4200
    jwilliams4200 Senior member
    Apr 10, 2009
    532
    Someone on hardforum just posted a good idea that hopefully Anand can use to find the firmware version of the dead 840 Pro:
    http://hardforum.com/showpost.php?p=1039341064&postcount=89
    Basically, you run these commands:
    Code:
    set devmgr_show_nonpresent_devices=1
    cd %SystemRoot%\System32
    start devmgmt.msc
    and then use the mouse to choose: View > Show Hidden Devices
    and you will have the usual device manager window except it will show devices that are no longer attached to your system.
    Expand "disk drives", double-click "Samsung SSD 840 PRO Series ATA Device" to open the Properties window, select the Details tab and choose "Hardware Ids" from the pop-up-list. The firmware should then be displayed. Mine shows DXM03B0Q.
  14. jwilliams4200
    Apr 10, 2009
    532
    I have two 840 Pro SSDs, a 128GB and a 256GB, purchased from newegg. They both have firmware DXM03B0Q. I have been hammering them for more than a week now and they are both fine.
    I have not seen any new reports of 840 Pro SSDs failing, beyond anandtech's and the poster on hardforum.com. The newegg reviews of the 840 Pro SSDs do not mention any units failing.
    I think the evidence is accumulating in support of Samsung's claim that the 840 Pro SSDs with the shipping firmware (DXM03B0Q) are not at risk for the same failure that anandtech.com saw.
    I still would not recommend for anyone to buy the 840 Pro to use for anything important until some more time has passed and/or we get more definitive news from Samsung. But unless someone reports an 840 Pro failure with firmware DXM03B0Q, it is looking like the shipping 840 Pro SSDs are doing okay.
  15. jwilliams4200
    Apr 10, 2009
    532
    The poster from hardforum just posted that he was able to find the firmware version of his 840 Pro SSDs in the kernel log of their testing machine, and they were DXM02B0Q.
    http://hardforum.com/showpost.php?p=1039341659&postcount=91
    Now if only Anand can look up the firmware from the "Show Hidden Devices" trick of the Windows device manager, we may be able to confirm that all the reported failures had the -2B0Q firmware.
  16. yefi
    yefi Member
    Nov 15, 2012
    46
    Is it just the 840 Pro shipping with an updated firmware, or does the vanilla 840 get it to?
  17. hhhd1
    hhhd1 Senior member
    Apr 8, 2012
    667
    #192 hhhd1, Nov 20, 2012
  18. Hellhammer
    Hellhammer AnandTech Emeritus
    Apr 25, 2011
    701
    4
  19. Eug
    Eug Lifer
    Mar 11, 2000
    22,229
    143
    I just steered a friend to the Crucial M4 actually, precisely because of the dying 840 Pros.
    However, I also told him to note the Crucial M4 firmware, since some of those have serious issues too.
    Geebus, it almost seems like SSDs are trying to compete with floppy drives and zip drives for unreliability.
  20. dawp
    dawp Diamond Member
    Jul 2, 2005
    7,400
    28
    has it been confirmed it's the firmware yet? I'm interested in these and will hold off for now.
  21. GPz1100
    GPz1100 Senior member
    Jun 10, 2001
    343
    Got one from amazon recently, DXM03B0Q firmware.
  22. davewolfs
    davewolfs Junior Member
    Nov 15, 2012
    Two weeks 24/7. Still no issue.
  23. Hellhammer
    Apr 25, 2011
    701
    4
    Both of our 840 Pros had the firmware DXM02B0Q in them, just got a confirmation from Anand. That's not to say that the retail units are issue-free, but they do have a newer firmware that supposedly fixes the issues we've been having.
    We now have an 840 Pro with the new firmware as well, lets see if we can kill that one...
  24. jwilliams4200
    Apr 10, 2009
    532
    Good times! :thumbsup:
  25. hhhd1
    hhhd1 Senior member
    Apr 8, 2012
    667
    I do hope you redo all the tests, specially the power usages tests.
    It was terribly wrong of Samsung to send to the reviewers a drive that has a different firmware from the one sold at retailers, when different firmwares could have different performance or have different issues.
Thread Status:
