Two quick questions for EVGA nForce 680i SLI Socket 775
johnleeRIP
36
I have the following:
Motherboard
EVGA nForce 680i SLI Motherboard - T1 Version, NVIDIA nForce 680i SLI, Socket 775, ATX, Audio, PCI Express, SLI, Dual Gigabit LAN, S/PDIF, USB 2.0 & Firewire, Serial ATA, RAID
CPU:
Q6600 Quad Core (stock fan)
RAM:
Corsair 4096MB PC6400 DDR2 800MHz (2x2048MB)
And I am installing this on Windows XP Pro SP2 32bit
There was a warning that 4GB will not work with XP.
Will I have any problems with this mobo, cpu, and ram combination?
Can 32bit XP handle ram that is 2GB PER STICK?????
Or should I have gotten FOUR 1GB sticks instead of 2 2GB sticks?
Does it make any difference ??
johnleeRIP
36
Also I have read some people rec reseating and applying special paste on this particular mobo to prevent overheating? If I don't OC will this be an issue for me?
Anyone ?
Quiksilver
4,725
No.
Yes.
No.
Also, sames you are using 32 bit XP, you will only see about 3.2GB of memory.
