OK guys i use not to worry about fan noise. I thought if i can keep my system really cool i really don't care how loud it is. I had this opinion until i got a thermalengine a few years back with a 7000RPM fan. This thing was about 50dba if i remember and my system sounded like a vacuum cleaner running that i could hear throughout the house. It cooled good for a k7 class cooler but it was WAY to LOUD. Now all my systems have the stock HSF which isn't to loud. I think the loudest parts of my sytems now are the psu which i plan to replace an enermax 400something psu because i find iits to loud. Anyways i digress. I ordered a scythe ninja a few days ago which 120mm fan that is rated 23.5dba for 46.5cfm and 1200rpm.
I guess my real question on this is does dba always tell you the real story on noise or are they somehow scewed? The rating on the scythe fan doesn't seem that good. Like here is a 2000rpm fan that puts out a lot more air and is quieter eventhough its almost spinning twice as fast:
http://www.newegg.com/Product/Product.asp?Item=N82E16811999127
but does dba always tell the truth? At what dba do you think you start to really hear the fan? 35dba? Im wandering what dba i want to stay below to have a quit system. What cfm minimum do you think you should look for in a 120mm fan?
Ok second question is:
Is all thermal paste made the same? Should i replace the thermal paste that came with my scythe ninja with artic silver or is thermal paste pretty much thermal paste?
