Two more case fans + rounded cables dropped my temps by...
lookin4dlz
688
Five degrees celsius on the CPU and six for the system!
I had 7v modded my two antec case fans, which added 1C to the temps. Today I received four rounded IDE cables and two Vantec Stealth fans from svcompucycle. I stuck the two fans in the remaining two case fan holders on my Antec 1040 case & replaced the ribbon cables. Boom, easy as that a dramatic temp drop :)
I have no idea whetehr the round cables help & I don't plan to swap them out to see. They are so much easier to work with - that's reason enough to have them. Additionally, I got a different color for each IDE channel.
The Stealth fans are very quiet and have no high-pitched sound as some have posted here. They make less noise than the 7v modded Antec case fans.
CurtCold
1,547
Sweet for you do0d, rounded cables help airflow alot, especially if you have 2 hardrives, then 2 optical drives.
