Two machines/Dual NICS/Problems...
Shame
2,730
I have 2 Windows 2000 machines connected via a linksys router for internet, and hooked together via gigabit NICs and crossover cable. ie. 2 NICS in each machine. They are connected using NetBEUI and TCP/IP.
Machine 1:
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : arizona
Primary DNS Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
#2
Physical Address. . . . . . . . . : 00-00-00-70-0D-0D
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 63.240.76.135
204.127.194.11
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : Realtek RTL8169/8110 Family Gigabit
Ethernet NIC
Physical Address. . . . . . . . . : 00-02-44-A6-09-6B
IP Address. . . . . . . . . . . . : 10.10.10.2
Machine 2:
Host Name . . . . . . . . . . . . : nevada
Ethernet NIC
Physical Address. . . . . . . . . : 00-02-44-AB-8A-42
IP Address. . . . . . . . . . . . : 10.10.10.3
Description . . . . . . . . . . . : 3Com EtherLink XL 10/100 PCI For Com
plete PC Management NIC (3C905C-TX)
Physical Address. . . . . . . . . : 00-01-03-CD-EA-18
IP Address. . . . . . . . . . . . : 192.168.1.3
204.127.194.11
NetBIOS over Tcpip. . . . . . . . : Disabled
I followed the instructions here.
Here's the problem:
At bootup, Machine 1 likes to make me wait like 10 minutes with "Applying Security Policy". I also cannot ping Machine 2 from Machine 2, but can ping Machine 1 from Machine 2. File transfers from Machine 2 to Machine 1 are fast. File transfers to Machine 2 from Machine 1 are slow. Internet works fine on both though.
What am I doing wrong?
Smilin
7,357
Why are you disabling NetBIOS over TCP/IP?
From "Arizona" do this:
\\10.10.10.3\c$
how fast does it come up?
now try:
\\nevada\c$
Put a connection specific DNS suffix on your private NICs while you are looking at things.
Shame
2,730
\\10.10.10.3\c$
now try:
\\nevada\c$
Both arizona and nevada come up quick...
RE: disabling NetBIOS over TCP/IP ... I always thought this was more secure.
I enabled NETBIOS, BTW...
RE: Put a connection specific DNS suffix on your private NICs ... How and why?
Thanks for your help, BTW...
petey117
755
there is no doubt that if the machine cannot pin itself then there is something flaky going on
do you ping by name or by IP?
Shame
2,730
BY IP.
