Heh? It sounds as though you are asking two different questions.
Anyway, it depends on which drives you move information between the most. If you copy information from harddrive to harddrive, have them on different cables because I hear only one device on a cable can be accessed at a time. If you move files from hardrive to cd and vice versa, make sure that harddrive and cd-rom is on separate cables.
