http://www.industrialtechnology.co.uk/2000/apr/papst.html
The two smaller fans placed side by side will move less than a total of 100 cfm. Two similar fans in series (stacked) will not move more air than one fan but it will increase the amount of pressure the fans generate so will support more movement into a higher pressure environment. - www.7volts.com
does that mean there is no point to place 3 120mm fans side by side since they won't move more air than one fan?
I just cut 6 120mm blowholes, 3 for intake (bottom of my case, places side by side) and 3 for exhaust (on top of my case, placed side by side)
