HI
I?ve been doing a some of copying of files and movies to cd?s and dvd?s.. I have a Plextor dvd/cd burner that is about 3 to 4 years old.
I was thinking of replacing the Plextor and adding a second dvd/cd burner. Yjat way instead of having to copy a cd or dvd to a file on the hard drive and then over to a blank cd or dvd I can send the data feom one burner to another.
Now my question is what makes a dvd/cd burner such as a Plextor that costs upward of $75 better then say one made by Pioneer or Sony or Lite-On or Asus, etc????
Cost is a factor because of buying 2 units.
My thought is if I buy 2 units I want them to be matching because of transfer speeds, etc.
If I do this I will put both units on one cable and make one unit the master and the second unit the slave.
And and all help and advice is needed!!!
Thanks
Dumbone
Thanks
Dumbone
