3DVagabond
- Aug 10, 2009
- 11,951
- 204
- 106
This will be only with Volta.
AMD will likely have it first. They've been working directly with SK Hynix on HBM.
The leak you are referring to, if it is true, the 1gen HBM is far less effective than 2gen HBM, according to the chart o VZ.
Rather more crucial for the APUs I'd have thought?
It actually makes sense why GTX880 could end up cheaper. If it is GM204, it is a real replacement for 680/770 GK104 even if it ends up faster than 780Ti by 20-30%. There have been plenty of instances when NV's next generation mid-range either tied or beat the previous generation flagship. As a mid-range Maxwell card, with 2x performance/watt, it could easily beat a 780Ti in a 200W power envelope and sub-400mm2 die size, and be priced at $499-579.
This strategy would leave room for NV to release GM210 in 2H of 2015 for $699+.
It is a welcome rumor if NV won't continue to raise prices as it will put additional pressure on AMD as well. In the past, new generation of NV GPUs got 35-70% faster at more or less the $499-$649 level. Let's hope NV stays in this band, and closer to $499 would be even nicer for the 880.
I guess this signals the end of an era where the high-end could be had for $500 and mid-range was sub-$300...
8800 GTX launch price = $600 (http://www.anandtech.com/show/2116/17) in 2006
It's 8 years later.
Adjusted for inflation, $600 in 2006 = $705.57 in 2014 (http://data.bls.gov/cgi-bin/cpicalc.pl?cost1=600&year1=2006&year2=2014)
Food for thought. We've been spoiled by other components falling in price faster than GPUs, and in many cases more horsepower/efficiency/etc. as well. GPU prices have not fallen as much; instead, high-end video card prices have been steady, while delivering more horsepower... similar to car prices holding steady while cramming in more and more features and specs.
The only issue I have with using the 8800 GTX as a poster child for the notion that GPU prices being steady over the years is that the 8800 GTX was a BEAST of a graphics card. Comparing the jump it brought to the industry to what the alleged 880 GTX will bring, the 8800 GTX was well worth the price.
The only issue I have with using the 8800 GTX as a poster child for the notion that GPU prices being steady over the years is that the 8800 GTX was a BEAST of a graphics card. Comparing the jump it brought to the industry to what the alleged 880 GTX will bring, the 8800 GTX was well worth the price. The 8800 GTX nearly doubled (and it did in some cases) the performance over the previous high-end.
I would buy the GTX880 if performance was 780 ti or better and priced at $500-$550. GTX870 would be better if it could at best touch 780ti and run $400.
Market right now is incredibly stale, upgrading from my 2gb 770 to anything else currently isn't worth it and the 2gb on my 770 makes sli not quite a viable option.Waiting for Maxwell sadly is my only option as well for others too.
If the GTX880 will indeed have 4GB 512bit memory and have a pricetag of under $600 where the GTX780 is now, I'll probably buy one.
It's 8 years later.
That was not that hard with more than double die size compared to G71 (7900GTX)
GK110 has brought even more than 2x over GF110 with just a die shrink.
GK110 is a real beast
Considering that everything that people are saying the 880 will and won't bring is coming completely out of one's own backside, I'm not sure it's valid to tout the 8800 as this massive overperformer as compared to the 880.
We don't know what the 880 will be. We don't. Anyone who claims otherwise is completely guessing.
GTX880 would need to be 3x faster than HD7970. Frankly I do not think even GM210 (980?) will be 3x faster than 7970/680.
I don't doubt this one bit. G80 was launched in the generation which followed G71, but GK110 was launched 2 "generations" after GF110. Heck, you might even call it 3 "generations" if you count all the way back to GF100. The issue is that prior to GK110, we were given a $500 GK104 to whet our appetite then GK110 was launched at the $650+ price tag. Normally, we would see the new high-end fully supersede the old high-end ala $550 GK110 replacing the $500 GK104, but nope, that didn't happen.
I'm sure we all know this by now but at the current rate at which node shrinks are being brought to the GPU industry, I think this pretty much means that there's going to be some sort of pseudo tick-tock cadence from here on out as I don't expect the first 20-nm GPU to be a big die.
How about we compare performance/$? This is where Nvidia needs some work, and if they bring out a card that performs better than the 780Ti at a cheaper price, I don't see much to complain about...
I don't care if the chip is labeled as GM853, and is the size of a pebble. If the performance is there, and the price is right, bravo.
