MetalWires
Hey I bought a hauppage (sp?) TV Tuner a while back and haven't been using it because I can't get good reception... I definitely think that it might have to do with the fact that I am just using the original antenna that came with it. If anyone could suggest a good antenna that i could use (it has to have a small sized jack on the end to plug into the PCI card, because the port to plug in the antenna sort of goes "into" the card,). Also I was wondering if there is some better software, that is compatible, then the stuff that came with it. Thanks alot
