TV tuner for under 80
videopho
4,185
29
I recommend the Kworld ASC-110, cost ~ $55 (AR).
Link
I use BeyondTV software for most pvr stuffs.
videopho
4,185
29
Originally posted by: bahamasc
So why do you recommend it (in terms of pros and cons). I am in the Bahamas so I may as well forget about a rebate unless its instant.
Simply it's inexpensive, easy to set up and most importantly, it works with my x64 OS too.
imported_K3N
1,199
too bad it has received bad user reviews.....
Never buy a product that receives 3/5 rating from newegg...
