Originally posted by: czech09
Doesn't really say if it connects via AGP or just regular PCI. I have a PCI-E motherboard so AGP wouldn't work.
Thanks for the link.
Originally posted by: FrankyJunior
Are you meaning to just watch TV on the computer or use something like SageTV to actually record the shows so you can watch them back later?
I'm using the Hauppauge PVR-150 card with SageTV and it works great. Only $130 or so (I think) for the card and the software from www.pcalchemy.com
If you just want to watch TV and not do the fancy recording stuff, you can just buy the card and use the included software to watch TV. Quality looks just fine.
Originally posted by: Engineer
Click me!
Off Topic (sort of), the above card isn't rated too bad as is only $15.99 + shipping after rebates. If you were e-mailed a $5.00 coupon, it would be $10.99 + shipping after rebates. Since it includes remote, not bad at all. Captures but not hardware.
Good Luck in your search.
Originally posted by: radioouman
External USB 2 (Gainward TV2GO) is a good choice.
But only if you have USB 2 ports.
Originally posted by: werk
Pony up the extra couple bucks and get a Hauppauge PVR-150 or a VisionTek Xtasy Theatre 550 Pro PVR, you won't regret it (both around $50-60 AR, search Hot Deals).
:thumbsup:
Two of the best hardware based TV tuner cards on the market.
I just bought an HDTV tuner card, can't wait until it arrives :thumbsup:
:thumbsup:
Does he need the hardware and extra costs if he only intends to watch, not record? (curious as to the economics of the deals).
Better video quality, more stable drivers (major manufacturers), I'd imagine CPU usage is less as well even if just watching, plus he can move to PVR software in the future if he wants. I'd say it's worth the extra ~$40.Originally posted by: Engineer
:thumbsup:
:thumbsup:
No they aren't, with the USB ones, the video and audio is always out of sync
Better video quality, I'd imagine CPU usage is less as well even if just watching, plus he can move to PVR software in the future if he wants. I'd say it's worth the extra ~$40.Originally posted by: Engineer
:thumbsup:
:thumbsup:
Some of us are just cheap@sses!![]()
