- Oct 16, 2000
- 327
- 0
- 0
We're getting the go-ahead to develop a 6-display kiosk at work (mounted from the ceiling, mainly hands off), 3 of which will be TV-tuner output from 3 separate PCs. How can you best do this with a limited budget?
* The remote controls for the TV tuners will interfere with each other if we put the IR receivers anywhere near each other. The only thing I can come up with is to buy 3 TV tuners (with remotes) from 3 different manufacturers.
* Is XP the way to go or will 98se be just as good with the newer TV tuner cards. We have licenses for 98se but not XP.
* As far as tuners, the Leadtek, ASUS, and Hauppage cards are the ones that seem to do the most for the least $$. I see there are new 10-bit phillips chips too, the ASUS 7133 uses that and is at newegg for $69. Any others cheap ones with a remote?
