- Jul 19, 2004
- 2,168
- 1
- 81
So, I am considering buying a basic tuner card, and there are some things I just don't know about them.
I have digital cable. Some channels are digital, some aren't. Will this card be able view all channels, or just the non-digital ones?
How do the tuners get the sound to the computer? Is there a cable (internal or external) that hooks up, or can I just stick the card in and it will work?
Do most tuners come with software, or is that something I will have to invest in?
Can you recommend me a good tuner? I want to spend around $50, but I am willing to go higher if necessary. I want to be able to record in decent quality.
Thanks in advance for the help.
Update: I found this, what do you think?
