tv to receiver connection?
khlee
240
what kinda output is needed in the TV to hook it up to a receiver? I have a nice receiver and a set of polk speakers and i was wondering what kind of outputs i need in a tv to connect the two together.
thanks!
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
thanks!
Are you talking about hooking the audio out of your tv to an input of your receiver so you can use your new speakers to watch tv?
Does your TV have RCA audio out connections? (red and white)
DaveSimmons
40,730
670
Most modern TVs have at least stereo audio output jacks that you can connect with standard RCA white/red cables to a "tv in" or "tape in" or most any other "in" you like.
If you have cable you could use the red/white outs from the cable box instead.
Some cables boxes (and expensive TVs) also have a digital out.
khlee
240
thanks!
yep. I currently dont own a tv.
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
thanks!
Shouldn't be a problem with any modern non-budget tv.
What kind of tv were you thinking of buying?
khlee
240
thanks!
im thinking about this one: link
do you have any recomendations?
im a college student on limited budget, btw
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
thanks!
That one should work just fine.
The Dolby Digital output will give you surround sound output from the integrated DVD player. I'm not sure if the digital output will work for cable/regular tv, but if not then you have regular stereo RCA outputs on it too from the description. :thumbsup:
I'm a college student too :)
Have fun.
khlee
240
thanks!
Have fun.
sweet. thanks!
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
Hmmm... I just looked at the back of it at circuit city and it looks like it only has a digital coaxial output.
I've never used a tv with digital output for sound, so I'm not sure if this will output normal tv audio too, but I would imagine so.
Can anybody confirm that it will output PCM stereo for normal broadcasts, cable tv, things connected to the front AV/inputs, etc?
EDIT: http://www.circuitcity.com/ssm/Magnavox...sm/oid/91326/rpem/ccd/productDetail.do
