TV card for Radeon VE, need help getting a card
clamrade
Hello. Since this is my first post, perhaps I should do a quick intro. My name is Jin Kim, and I'm an electrical engineer in MN.
I've been looking for a TV tuner card to use with my Athlon, ECS motherboard system with ATI Radeon VE (aka Radeon 7000). I bought the AverTV Studio for its 16 channel preview, time-shift, and remote control features. THEN I found out that it's not compatible with the Radeon. We'll, I am not really sure if it's not compatible (since the Taiwan web site claim that it is, but the US web site claims it isn't) but I rather not go through the install procedure if it's got a known compatibility issue.
So, may I get a suggestion for the card to get with the above features? I have no hesitation about using third party driver/software to get it working (as long as the cost is not prohibitive). Thank you for your help.
Rottie
4,795
I am just like you...I have ECS mobo, Radeon VE except that I have Duron (Spitfire) I have no problem with ATI TV Wonder VE tuner but you cannot use it if you have digital cable line.
You might want to try it out.
clamrade
Yeah. Thanks. It's just that TV Wonder is so feature poor! No channel preview, no time-shift, and no remote! And it ain't cheap!
